Question on datalogging values in Evoscan
Old Apr 16, 2009 | 05:29 AM
AWD_Terror's Avatar
Just curious if any settings need to be tinkered with on initial setup with evoscan other then selecting the car maybe?
Im looking at my datalogs, and I just dont buy the info its giving me.
It seems to me like the values it shows me for timing and AFR are not what it appears to be on my wideband off the top of my head and also on the maps in ECU flash.
Should the table values for AFR points and Timing in ECU flash be dead on representation?
Like if you set it for 11.5AFR across the board in boost, should you see 11.5AFR solid across on the logs and wideband?
Cuz I dont. I see logs of high 10's to low 11's
Timing I see of 7-8 degrees at full boost on the logs, but on my maps they should be like 12-15 or so.
Also when trying to compare values on the graphs things just dont jive up IMO. If I select diff values on the same points of the chart and it will show the other values too. They never match up.
I dunno maybe Im crazy, but this thing doesnt seem right to me.
