Immobolizer possible issues with apexi
Old May 15, 2009 | 03:23 PM
yellowevo82's Avatar
Is there away to disabe or fool the system, i think this is why my car wont start..
Old May 15, 2009 | 04:39 PM
Dragon-V's Avatar
there should not be a problem with the immob as the apexi dont have it so the car should start.
Does the fuel pump kick in when you turn the key and do you have fuel at the rail?
Old May 15, 2009 | 05:11 PM
okay, pm sent.. i have fuel and pump is on.. just abs no spark, check the ecu and the wirring is fine , brand new cam/crank sensors and all fuses are good
