What is needed to log the afrs from a aem uego
Old Jul 13, 2009 | 04:19 PM
evo821's Avatar
looking to find out what is needed to log the afrs from my wideband. can i make one or can i buy one?
any info is greatly appreciated...thanks
codie
Old Jul 25, 2009 | 09:07 AM
XracerS13's Avatar
you'll need some type of data logging module. You can get one from innovate motorsports. You can configure the 0-5v output from the wideband to be logged.
http://www.innovatemotorsports.com/products/ssi_4.php
You can PM me for a price as well.
Old Jul 30, 2009 | 10:34 AM
Z_Lancer_Man's Avatar
If you have a laptop with a serial port or a USB-Serial converter, you can log your AFRs for almost free. You just need to buy a D-Sub connector and use the Windows HyperLink terminal as explained in the AEM UEGO manual:
http://www.schnitzracing.com/manuals/AEMWBK.pdf
If you have the Tactrix cable, you can log the AFRs directly from your ECU by replacing your rear O2 sensor with the wideband sensor and hooking up the white 0-5 V wire to the rear o2 sensor input wire into the ECU. Here are the installation instructions I followed:
https://www.evolutionm.net/forums/ec...ial-cable.html
I've been logging my AEM UEGO wideband through EVOScan now for 2 weeks - works great!
