Removing RRE dual map switch????
Old Oct 19, 2009 | 06:46 PM
evodan_socal's Avatar
Question Removing RRE dual map switch????
So, I had my 03 EVO tuned by RRE in Dec 08. It ran great and made some pretty good numbers on the dyno. Around Apr 09 the car started running really rich, blowing black smoke out of the exhaust, and had uncontrollable boost spikes. I tried contacting RRE, but no love.
Frustrated, I tried changing out obvious parts starting with the dual stage MBC. That stopped the boost spikes, but still running rich and and blowing smoke. Then I changed out my Greddy RS BOV with an AP BOV, that helped a little bit, but still rich and smoking at WOT like Cheech Marin. Tried contacting RRE again to get my ECU reloaded, but I got no reply.
Finally, I decided to send out my ECU to Dynoflash. When it came back, it wasn't running rich, but I needed to change a few things. The boost solenoid needed to be bypassed and the stock injectors had to go back in. I am still getting a CEL though. I would guess it is because the dual map switch is still wired into my ECU.
My question is ... does anyone know how to remove the switch and wiring?
Thanks.
Old Oct 20, 2009 | 04:33 PM
turbolarry's Avatar
Try posting here;
http://www.socalevo.net/index.php?op...=37&board=56.0
Mike checks regularly.
Old Oct 20, 2009 | 10:23 PM
SoCal Rally's Avatar
^^^ Not so sure.
Anyway, I think it's likely the dual map switch RRE installed is just a 'Jack of Trades' alt-map switch. Install instructions for 'Jack of Trades' alt-map wiring harness is here: http://dsm-ezine.com/Install_Instructions.zip Just do the reverse of the install instructions to remove the relevant wiring.
Old Oct 21, 2009 | 11:19 AM
Jim in Tucson's Avatar
I'm really confused here. I had my dual map set up done at RRE as well. The EVO VIII does not require any kind of switch to be installed, as does the EVO IX. The EVO VIII uses the ICS switch in the console.
In any case, if you do have a map switch, and if you are now flashed back to a basic straight up ROM w/o dual maps, the switch should do nothing. Simply cut the wires, remove the switch, and tape off the ends.
Old Oct 22, 2009 | 05:20 AM
True, the Evo VIII does not require a switch to be installed for alt-map switching, however it is one of the methods supported. In fact there are three separate methods supported:
- ICS switch
- TPS
- Alt-map switch & wiring harness
Old Oct 23, 2009 | 10:00 PM
evovin's Avatar
http://driven2modify.com/showthread.php?t=21863
Old Oct 24, 2009 | 10:38 PM
thanks guys.
awdordie
Jun 15, 2017 10:00 AM
Clutch450
Nov 1, 2016 11:30 AM
DWILSON357
Feb 10, 2016 03:27 PM
89turbosupra
Oct 17, 2015 03:57 PM
jamesinger
Dec 11, 2012 10:51 PM
