data logging
Old Oct 22, 2009 | 04:06 PM
ch53avitech's Avatar
data logging
When data logging with evoscan, what are the most important options to log? Right now I left it the way I got it so the first 20-25 boxes are checked. Thanks for the help.
Old Oct 23, 2009 | 07:06 AM
turbolarry's Avatar
The most important items to log are;
throttle
RPMS
timing advance
knock sum
and...
Do the 2 byte load mod in your ROM for log 2 byte load.
Then, depending on your set up and what you want to do, maybe;
Battery (hp estimates)
IPW/IDC (running higher then you though, huh?)
Fuel trims (injector latencies)
JDM MAP (upgrade the MAP sensor, add some code, and log boost)
Wideband
Wastegate stuff for stock/3 port solinoid.
Good stuff. Best $25 I've ever spent.
Old Oct 23, 2009 | 01:41 PM
Thanks for the reply. How difficult is it to patch the 2 byte load mod?
jakgal04
Mar 28, 2016 08:16 AM
drsrock
Sep 13, 2014 02:53 PM
SmurfZilla
Jul 22, 2012 03:33 PM
TIGERJC
AEM EMS
Sep 15, 2010 12:02 AM
Jim in Tucson
Mar 26, 2010 08:54 AM
