Is there a simple way to data log?
Is there a simple way to data log using Tactrix cable while on the track. My car is a work in progress, and I would like to have telemetry to look at after each run group.
The factory ecu will not show you oil pressure or afr. You can wire in an external wideband and setup evoscan to get it through the obd port, but I don't recall seeing anyone do that with oil pressure.
I had a zeitronix in my car already, so I got their SD car recorder unit to add on. Very simple and can record a ton of data on a micro SD card. The downside is there are limited channels (I get boost, afr, rpm, tps, egt and oil pressure). I still need to figure out what I want for gps and accelerometer data and how to integrate it all.
Thanks.
That's exactly what I wanted!
RA09
10
Feb 4, 2013 09:19 AM
DataLogLab
12
Apr 15, 2004 01:16 PM
