Need help - agressive throttle work and idle @ Kelford's 272
Subscribe
Dec 8, 2009 | 11:26 AM
Hello friends. I'm from Poland and few days ago I've sold my Evo 9 because, I've built this:
http://www.cardomain.com/ride/3343359, http://www.youtube.com/watch?v=-_47Wq_ATj8
My problem is very agressive throttle work. I mean - when I put gas very gently, car just kicks to front very hard and the same, when I ease down.
Second problem is very irregular idle. My cams are Kelford's 272'.
What should I do ? Mechanical I think everything is ok, so this problem prep ECU. I have Ecuflash, but I am....yyaa amateur in this :/
Please help
Reply 0
Dec 8, 2009 | 11:42 AM
HAve you tried adjusting the throttle cable? That might help for that problem, not to familiar with the Colt and what tunning device you are using. I do know that for DSMs you can make the iddle not as bad by tuning the car with DSMLink or something similar. Hope that helps.
Reply 0
Dec 8, 2009 | 11:51 AM
ECU is from Evo 9, just like all electric harness. What is procedure of adjusting the throttle ?
Reply 0
Dec 9, 2009 | 01:06 PM
And one more thing: My car do not have EGR system, engine is from Evo IX MR. Maybe I should disable EGR function, but how ?
Maybe should change other values? Like RPM, ignition or... ?
Reply 0
Subscribe
