AEM EMS Get tuning help for your AEM EMS system.
AEM EMS questions
Old Aug 9, 2011 | 07:00 AM
Evolv3dEvo8's Avatar
AEM EMS questions
How are you guys acheving a "Choppy idle" using AEM? I have Kelford 280 s and the car still does not sound as agressive as most HKS 272 cars....
Please chime in with advice and what tables, settings etc are beiong changed.
Thanks
Old Aug 10, 2011 | 02:39 PM
browningderek's Avatar
Sounds like your idle rpm is too high. What is it? You should be able to idle around 1000-1050rpm .Also read this thread.
https://www.evolutionm.net/forums/ae...e-aem-ecu.html
Old Aug 10, 2011 | 11:37 PM
BillSpec's Avatar
If your idle isnt chopping thats a good thing IMO. If you run a higher amount of timing it tends to make the idle smoother depending on your target idle rpm. Dereks thread that he pointed out to you is a proven method.
Idle timing is generally 14-18* below 1500 rpm. You should shoot for a solid 900 or 1000.
AFR will make the car chop too. Too lean/rich and it will lope like crazy.
Old Aug 11, 2011 | 03:11 PM
Dude, if its smooth at 1000rpm in jealous!! I have done everything i could think of and the best i can get is no loap with the a/c on but it still loaps when its off.
Old Aug 14, 2011 | 05:56 PM
Anyone else?
Old Aug 15, 2011 | 03:01 PM
BillSpec's Avatar
Take a vid with the laptop open while running at idle
Old Aug 16, 2011 | 07:09 AM
Will do, Looks likt the timing may be retarted a tooth.....
Old Aug 17, 2011 | 11:24 AM
BillSpec's Avatar
No bueno.
Old Aug 17, 2011 | 12:08 PM
Lol ???
Old Sep 2, 2011 | 08:58 AM
superslowEvo04's Avatar
ive heard aem ems is nothing be problems? how is it for you?
Old Sep 3, 2011 | 08:06 PM
TheBoz's Avatar
What ever you heard is just crazy. They are a fantastic unit.
Any ECU is only as good as the tune on it, that even goes for stock ecu's.
razorlab
Apr 2, 2016 11:01 PM
06ravenmr
AEM EMS
17
May 30, 2010 11:03 PM
2JZfan
10
Aug 20, 2009 11:38 AM
MirzaJinnah
May 23, 2007 01:44 PM
metaphysical
10
Oct 26, 2004 12:04 PM
