Check light flashing with powerfc
Old Apr 22, 2010 | 03:27 AM
1_DARKANGEL's Avatar
Hey guys!
Im new to the forum from Trinidad W.I. I drive Ralliart GSR RHD EVO VII. I have The Power FC L-Jetro installed. It was working fine untill I got the car back from the Body shop and found that mostly when the car is cold that when I power the car as it reachesor just exceeds 80degC the car feels like a fuel cut 1st ,the check light falses abit and knock goes up abit at times, the amont varies. I cant seem to correct the problem. It only stops flashing when i richen up the mixture quit a lot at through out(terrible power). What could the body shop have done to cause thois problem? they did clean my engine bay as I found a few vacuum tubes out, and clogged fuel regulator boost tube. I`m I missing some thing? Is thePower FC damaged? Please help!!
Old Apr 22, 2010 | 09:44 AM
xska's Avatar
which part of your car was damaged? Did you damage front end ?
You may have to bleed coolant system, check commender (etc-switch sensor check) for weird voltage.
Also check turbo to air flow meter pipe for leak.
Old Apr 22, 2010 | 04:24 PM
arghx7's Avatar
What are your peak airflow and knock readings?
Old May 24, 2010 | 07:26 PM
saltydog's Avatar
call me and I will sort it out
358-3466
ryan
SkippygoluckyIV
Nov 15, 2015 12:59 PM
SkippygoluckyIV
Nov 13, 2015 03:31 PM
mr evo7
Jul 26, 2015 02:55 AM
Laurieandmike
Jun 2, 2015 10:00 AM
siduolocin
Feb 9, 2012 11:34 PM
