evo 7 2.3 ID2000cc help
Old Jul 17, 2015 | 12:50 PM
mr evo7's Avatar
Good day
First of all i don't have any tuning Knowledge. I am posting this on behalf of my tuner
I have just finished building my evo 7 and my tuner is having abit of issues getting the ID2000cc to work proper. The issues we are facing are as follows.
Very rough and lean idle (16 to 18 on AFR gauge)
Car seems to run abit rich just before peak boost (9 on AFR) then gets to about 10.9.
Car almost stalls at every stop sign and cannot take off smoothly unless revved up.
My mod list is as follows.
2.3 (9.0.1)
Stock intake and TB
Gsc s2
1mm+ valves
Pte 6262
Omni power 4 bar map sensor
Stock ecu tuned using tephramod.
Stock MAF sensor.
I would appreciate any help with controlling theses injectors abit better as it is also my tuners 1st time working with Id2000cc.
The fuels we are running.
93 octane low boost at 1.2 bar boost
E50 high boost 2.0 bar.
Thanks in advance guys 👍
Old Jul 17, 2015 | 06:48 PM
2winscroll's Avatar
You need minimum injector pulse width patch for your ROM. I also recommend Injector linearization patch but not necessary. What ROM are you running?
Old Jul 17, 2015 | 06:51 PM
2winscroll's Avatar
Check this out
https://www.evolutionm.net/forums/ec...nimum-ipw.html
You should also post this in the tuning forum might get more responses.https://www.evolutionm.net/forums/ec...ion-table.html
Old Jul 20, 2015 | 11:30 AM
SeanV's Avatar
Originally Posted by 2winscroll
Check this out
The ROM has the minimum ipw patch.
So to elaborate.
The Injector latencies and scalings I am using are those posted for the ID 2000 as posted by Mr Fred.
I can get the car to idle at round 14.7 give or take and get the afr more or less where I want them while in open loop.
A few days go by with the car standing and the next time I drive it without changing anything, car idles very lean and runs rich on WOT.
Or on other occasions it idles very rich and is lean while in open loop.
Seems to have a mind of its own.
Driving me insane.
I will try the linearization patch and see what happens.
Old Jul 20, 2015 | 03:28 PM
mr evo7's Avatar
So to elaborate.
Driving me insane.
This is my tuner
Old Jul 21, 2015 | 01:13 PM
mr evo7's Avatar
BUMP. anyone with some info please help
Old Jul 23, 2015 | 01:51 PM
mr evo7's Avatar
C'mon guys would really appreciate some help
Old Jul 26, 2015 | 02:55 AM
mr evo7's Avatar
Bump
Dragking2189
17
Jun 7, 2012 10:32 PM
louiesevox
Apr 9, 2012 03:04 PM
Dragking2189
14
Aug 28, 2011 05:39 AM
RSMike
31
Dec 1, 2010 01:30 PM
Magnumpsi
Nov 28, 2009 12:15 AM
