cat cel fix question?
I have an 03 evo 8 i am runing 96530706 rom with the v7 mod the day before putting on the v7 the car started to blow the engine fuse I found it was a bad rear o2 sensor so i took out the sensor to get the car to run my question is can the cel fix for the rear o2 work if there is no sensor because it still throughs the code with the cel fix on if I clear the code it will stay off tell the second time i start the car then come back on can anyone help The code is p0141
