quick log for those that like looking at logs
Old Aug 8, 2010 | 01:23 PM
leecavturbo's Avatar
yes i know i should get rid of column 20-40 and have better res up top. i will sort that soon.
holds load rather well up to 6.5k or average ?
http://www.keepandshare.com/doc/2139...m-1-5-meg?da=y
3" Tbe,cat delete,ported 10.5,ebc,walbro,21psi,tune
Old Aug 9, 2010 | 09:49 AM
turbolarry's Avatar
You need to do a 100% throttle pull from 3000 to 7000 RPM's to see what is really going on. A second or two of WOT says nothing. Also log the basics to keep it simple; RPM's, Throttle, Timing, load, knock, and boost and afr if you can.
Old Aug 10, 2010 | 06:35 AM
yes sorry it its wasn't a "pulls" log just a log of a drive out
deleted the 20-40 columns does this look right i.e i got the right values ported to the right columns ?
before
after
Old Aug 10, 2010 | 10:06 AM
turbolarry's Avatar
If it drives OK then stick with it. If not maybe go back and try deleting columns 0, 10, and 20 since they are all practically identical. Any load/rpm values in those area would reference column 30, which is also identical.
Old Aug 31, 2010 | 02:13 AM
the scaling works seems smoother but might just be psychological.
struggling to hold 21psi all the way duty cycle upto 85% so far
conservative timing up top for good quality fuel?
3rd gear (six speed)
http://www.keepandshare.com/doc/2199...9-am-271k?da=y
ekizenbe
Feb 4, 2011 09:58 PM
EvoX-11
Nov 23, 2010 12:48 PM
4g63girl
Oct 29, 2010 07:00 AM
21Evo-lution
For Sale - Wheels / Tires
25
Sep 5, 2010 06:16 AM
21Evo-lution
Aug 12, 2010 11:18 AM
