Broke the evo :(
Old Aug 21, 2010 | 12:48 AM
EVO8STI's Avatar
Originally Posted by erald01
you are the noob since you have a looooooot less posts than DC2toEVO8
ill agree with that, no problem there, but any person who deals with evos should know that that is obviously a massive boost leak especially if he has 500 post he would have read something similar to his problem and not posted an other thread when this has already been talked about at least 500 times. just saying with his "experience" he should know whats whats wrong and not posted a re re question... so there ya go. do you even look under the hood before you post questions?
Old Aug 21, 2010 | 09:48 AM
usacchamp's Avatar
I had this happen too
Old Aug 21, 2010 | 10:20 AM
DC2toEVO8's Avatar
obviously i know there might be a boost leak i wanted to hear everyones opinion before i get into it just to see WHAT ELSE TO EXPECT, i posted it so i can gain other unknown reasons i mean i dont own a shop or anything im just a student thats a member on this forum, i mean i never know a re re like you would read it and get mad? all im saying is fine if you think this thread is stupid sorry but does it help me know a little more before i crack everything open yes. "do i look under the hood before i post this question? well a question for you mr. damn im perfect did you check your tampon i think your on your period. so just please leave this thread alone and bring that anger somewhere else. but i still thank you for your time.
Old Aug 21, 2010 | 10:29 AM
Evo_nv's Avatar
does the car still idle? or do you have to keep on the accelerator for it to idle? this kinda sounds like the problem i had when i ended up having to buy a new IACV (idle air control valve) a very simple yet expensive fix... hope you figure out the issue soon!
Old Aug 21, 2010 | 11:29 AM
EVO8STI's Avatar
you're so clever with you tampon joke, haven't heard that one before.
im just saying do you not ever get tired of reading the same god damn thing over and over every day cuz someone like you cant search thro the threads. i said its a re re question calling you a re re and you dont need a shop to pop open your hood. im a 21 year old student as well so we are in the same boat there and that makes no diference to me, btw is your car fixed yet? go buy some t bolt clamps and then boost the **** out it
Mr. Perfect
Old Aug 21, 2010 | 11:35 AM
EVO8STI's Avatar
i dont think post really matter all it means is you talk alot, im sure there are people with 2000 post and i know more then them and im sure there are people who have like 20 post and could school me on my own car.... so post dont really matter when you cant idenifly a obviosly massive boost leak
Old Aug 21, 2010 | 03:17 PM
DC2toEVO8's Avatar
since i restarted the battery the ecu resetted it idles be low like its going to die out thanks!
Old Aug 21, 2010 | 03:36 PM
assaultman2004's Avatar
Originally Posted by DC2toEVO8
So i was coming back from the bar the other night and i was boosting roughly around 22 pounds of boost then boost cut and the engine start slowly dying down it self so i pulled over and soon enough it dies.. and it keeps on dying so i drove it home roughly 5 blocks? (misfiring the whole time ) and now when i start it its running very rich sounds like im running cams (the misfiring) and the keep sounds like it wants to die out... plugs are burnt smells like gas help!!!!! fellow evom members!
Along the lines im thinking with the help of my friends its either the head gasket or the coil packs has jumped sparks and gone bad... i've checked the maf its on tight... im posting because i want to know if this happened to anyone else? and knows almost exactly is wrong with it... thanks:hel pme::helpm e:
Well boosting at 22 psi from the bar is your first problem!
Old Aug 21, 2010 | 03:50 PM
5LEEPERISAH23I's Avatar
i dont get why people have to ruin threads by not making them relevant to the topic and just help the guy.
First i would do a leak down test to see if there were any boost leaks.
If there is no boost leaks, it is going to cost big money to fix!
NEVER use flash maps!! every car is different even with the same MODS!!! The Flash map could of possibly broke your motor!
Old Aug 21, 2010 | 03:52 PM
gsrboi80's Avatar
So you still have not boost leak tested the car or checked for a popped coupler????
Old Aug 21, 2010 | 03:57 PM
bigturboevo8's Avatar
dont get this thread at all.. not much feedback coming back from the guy with the problem..
Old Sep 8, 2010 | 10:00 PM
artisticspawn's Avatar
Not to add fuel to the fire, but I also experienced the very same situation as commented by other members. I was at full boost, felt loss of immediate power, followed by a barely noticable woosh sound for lack of a better word. I had to drive home about 2 miles as it was night time and had a horrible time keeping the car from dying by going through the gears rather quickly all the way into 6th so that the car could run at approximately 25 mph without dying. When I got home I immediately opened the hood only to find that my intake hose blew off even though earlier in the day I had replaced the stock worm drive with a T-Clamp (never mind that I used the wrong sized T-clamp). The reason the car acted erradict was simply because the MAF senser has no clue what to do to compensate for the massive air leak and the ECU goes haywire. Something to keep in mind is if one is ever on a long trip out in the middle of no where and this where to happen, what is one to do if one does not have a replacemnt hose on hand... I guess if you have a Tatrix cable one could try to tune it to run with the lack of boost.
Old Sep 8, 2010 | 11:45 PM
spoolme's Avatar
mikey wtf are you doing, bowing **** up lol
any updates? did you get the compression checked/ boost leaks?
Old Sep 16, 2010 | 06:40 PM
I just had another jose pop off last night after I had switched the oem worm drives to t-clamps. The problem is that I purchased them too big. I wonder if there is any thread or if anyone knows where we can find the proper sizing of each tube so that I can order some more correct sized t-clamps online (that is the problem I do not have any local shops offering t-clamps and thus cannot take the old ones to compare).
Old Sep 16, 2010 | 06:46 PM
jasserv's Avatar
here ya go... this should help you out.. .i bought the same thing from these guys
http://www.siliconeintakes.com/produ...2ad49dce9c7307
