Timing help
Timing help
So I just installed some HKS 272 cams. I was tuning for the cams and was wondering what the normal amount of timing around 5500-7500 is. In order to get rid of the knock i had to lower the timing quite a bit compared to my tune before the cams. If someone can post what their average timing is for the rpm range at about 255 load. I run 93 octane and no alch/meth stock 9.8 hotside turbo and 23lbs boost if it helps. Thanx
It's going to be difficult to compare someone else's timing map to yours as each car behaves differently...post up a coupe logs of before and after the cam install, maybe you'll get more feedback that way. Like veszett said, were you logging afr, boost etc.
Evo_Goodness
Sep 22, 2016 11:37 AM
My03evo
Jun 29, 2011 08:51 PM
