Cams help??
Old Jul 28, 2012 | 04:25 PM
AEvans190's Avatar
Cams help??
When I pulled off the timing belt I did not have everything at top dead center. So I turned the cams manually and did not remember which way I rotated each cam. I left the crankshaft at the position where I took off the timing belt...
What are my options to get the timing and sync of the cams correct with the crankshaft?
Thanks for your help! This forum is very helpful and I appreciate everyone's support
Old Jul 28, 2012 | 04:30 PM
Blue91lx's Avatar
So your crank is not at TDC, correct?
Old Jul 28, 2012 | 04:39 PM
AEvans190's Avatar
Yes that is correct... The timing marks on the cams were facing down before I turned them, I just do not remember which way I turned them or even if they were turned the same way.
Thanks guys.
anthonypazsd
135
Apr 2, 2026 12:56 PM
EvolutionRacing
Jun 1, 2016 07:12 PM
onix175
Lancer Engine Tech
Feb 19, 2016 04:54 AM
kansaslancer02
Lancer Troubleshooting
Apr 10, 2008 03:52 PM
CHOZEN_Lancer
Lancer Engine Tech
13
Feb 8, 2007 07:42 PM
