HELP ME! Lancer aint running right
Old Feb 1, 2007 | 02:36 PM
CHOZEN_Lancer's Avatar
Exclamation HELP ME! Lancer aint running right
Well after i put in a new crankshaft position sensor a couple of things went wrong. Primarily, my timing went off and i keep misfiring. However i never touched the timing belt. And also now my AC wont work and the check BATTERY and the BRAKE lights are always on! Im oh so very confused.
Old Feb 2, 2007 | 11:07 AM
ok here's a list of everything that now doesnt work
Signal lights + hazards
A/C and blower fan
Engine timing is off (keeps spitting out CYLINDER MISFIRE code)
BRAKE light is always on
BATTERY light is always on
i really dont know what could have caused all this when all I changed was a broken crankshaft position sensor that was broken. I checked all fuses and theyre good.
Old Feb 2, 2007 | 11:56 AM
TougeOZ_04's Avatar
got a OBD II sensor?
Old Feb 2, 2007 | 01:15 PM
Question
yes it reads that the catalyst sensor is below threshold (i got test pipes) and the other code says: RANDOM/MULTIPLE CYLINDER MISFIRE DETECTED
Old Feb 2, 2007 | 04:37 PM
Tha one's Avatar
check ur plugs wires and coils maybe tha could be tha problem for the missfire
Old Feb 2, 2007 | 07:48 PM
sykou's Avatar
did you unplug the batt yet?
Old Feb 2, 2007 | 11:01 PM
Hitthatluugh's Avatar
definately make sure you unplugged your battery and let it sit for a minute, and get a timing light and check it with manufacturer's specs... sry i dont know too much about the 2.0...
Old Feb 2, 2007 | 11:36 PM
Go2fast's Avatar
Hey bro your pretty local to me!! Im from the Cocoa/Port st john area but live over in orlando now. Whats the deal with the crank sensor? How'd you break it? Where did you buy the new sensor from????
Old Feb 3, 2007 | 04:18 AM
Myszkewicz's Avatar
I think you either blew your main alternator fuse, or you have a dead alternator. Either one could cause all the symptoms you have. The Battery and Brake lights are the tipoff, but the misfiring and malfunctioning electrical systems are clues, too.
Check the fuses, see pics below. If those are good, check the voltage at the battery with the engine off, should read between 11 and 12v. Then start the car and measure again. Voltage should read between 14 and 15v with the car running. If the voltage doesn't change, it's probably your alternator.
First one:
Second one (fusible link #1):
Old Feb 4, 2007 | 09:52 PM
are those fusible links 2 and 3 relays or actual fuses?
Old Feb 5, 2007 | 07:35 AM
Myszkewicz's Avatar
They're fuses, but those aren't the ones you need to check. #2 is a 50A fuse that powers the A/C clutch and radiator fans. #3 is a 60A fuse that powers the ABS system, if your car has it.
The only one in that picture you need to check is #1.
Old Feb 5, 2007 | 07:43 AM
bluebyu36's Avatar
defnitly dont sound like your timing belt, i bet you all your problem's are tied togther!
Old Feb 5, 2007 | 04:08 PM
checked them and theyre all good!. And to add to the list, when the engine goes above 2k rpms, the intake sound waaaaay loud. louder than ever before. im so confused!!!
Old Feb 8, 2007 | 07:42 PM
well the AC now works(fuse) but it still misfires and the BRAKE and BATTERY lights are still on. My alternator apparently works. It outputs a little over 12 volts. I also tried the alternator by having the car running and disconnecting the positive btt terminal and the engine kept running the same.
Does anyone know if theres a main realy for like all the hazards and the signal lights.
And also what does that FRONT ECU control? i know it has something to do with the headlights.
ub.chae
Lancer Troubleshooting
24
Jan 26, 2020 11:28 AM
s0hn
17
Jan 19, 2017 06:30 PM
justin5994
Dec 16, 2015 09:16 AM
Lancer XI1
Lancer Engine Tech
23
Sep 29, 2010 02:20 AM
nasty8evo
Sep 4, 2008 05:38 AM
