e- manage with harnesses
Old Nov 26, 2003 | 10:29 AM
evoego's Avatar
Registered User
I have the e-manage with ALL available harnesses that I am about to install. can someone clarify exactly which ones I truell y will need or is it ALL of them since I have them. thanks and all help will be appreciated.
Old Nov 27, 2003 | 07:03 AM
Guru's Avatar
You do not need injector harness. Just the tiiming harness. You can use the extra wires on the timing harness for your injectors. That's all you need to get going. Make sure to upload firmware 1.36 which is the latest version and calibrate your TPS sensor.
Old Dec 29, 2003 | 05:50 PM
darkturbo's Avatar
So do you even need the timing harness or just the emanage and what it comes with??? I ask this because I was told by a local shop that if you get the profec e01 and emanage you dont really need any addt harness.
Old Dec 29, 2003 | 06:04 PM
ghostrider's Avatar
If you only install the e-manage, it will only be able to read the a/f since that's the only line the e-manage itself splices into. The other harnesses will allow you to control other things (timing, injector duty, boost).
Old Jan 2, 2004 | 06:15 AM
Guru's Avatar
YOu need the timing harness yes if you want to control timing and I use it's extra wires for the injectors myself. It is irrelevant whether you have the E-01 or not. Your local shop is NOT an e-manage expert obviously.
Old Jan 4, 2004 | 08:17 AM
darkturbo's Avatar
Yep thats what I figured. I think they are a little
Old Jan 26, 2004 | 01:01 PM
JeffWels's Avatar
Dan would you be able to tell me how you used the ignition harness to wire up both ignition and injector functions? Also is the boost pressure sensor and harness needed if you are running the E-01? Is there any benefit to running both the E-01 and the emanages boost pressure sensor and harness?
Old Jan 28, 2004 | 08:53 PM
Guru's Avatar
The boost pressure sensor and harness are only necessary if you want to map for boost. If you have E-01 you can just buy the boost connection cable which passes the E-01's boost signal to the E-Manage. As for the wiring, you only use 4 wires on the ignition harness for the EVO ignition system so you can use the rest to hook up the injectors without having to buy an injector harness.
