notchy gears?
Old Sep 22, 2010 | 07:20 PM
Frank120's Avatar
notchy gears?
when i shift it feels real notchy should i flush the trans? if so what should i use syncromesh?
Old Sep 28, 2010 | 10:58 AM
DarksideZ's Avatar
How many miles are on the car? Have you ever replaced the transmission fluid before?
Old Sep 28, 2010 | 11:07 AM
nytalonTSi's Avatar
My 05 MR is the same way very notchy. Flushed the fluid out(I can only use the diaqueen) and it seems to be the same.
You can use synchromesh, but yeah if you have never changed the fluid that should help a bit. I'd also take a look at Redline too.
Mitsu trans are all notchy from the get go. You can always add ams shifter bushings under the hood and at the shifter base later.
Old Oct 1, 2010 | 08:16 PM
stackhouse's Avatar
Got my 03 with 60k. Was kinda notchy, especially going to 3rd. I changed my fluid with BG. Still notchy, but not so much. Just the nature of the beast.
IF you've never changed the fluid out before, I would highly recommend it. Just be sure its GL-4.
Old Oct 1, 2010 | 08:28 PM
toysgetsmoked's Avatar
try redline mt 90 but if your pushing higher hp then use the light shock.
Old Oct 1, 2010 | 08:29 PM
Diaqueen is great for stock power levels..
Old Oct 1, 2010 | 08:43 PM
evo<3's Avatar
i got the 6spd have tried diaqueen and redline fixin to try mil spec. castrol syntorc heard it get rids of the notchiness
