tuning question - VDR chart
Old Oct 1, 2010 | 01:36 AM
veszett's Avatar
i've noticed something strange on the VDR charts when im doing a comparison with past pulls. can someone tell me whats going on with the drop between 3500rpm and 5000rpm? i did these a few months apart and since then i have fitted a s90 70mm tb and had the stock IM ported to match. surely this will not cause this? i have noticed the WGDC is higher thru the whole pull and the load down low is lower than previously, could it be a boost leak? the gasket that came with the TB was only paper and i also fitted a P2R thermal intake gasket between the IM and head. thanks.
Old Oct 13, 2010 | 11:46 AM
Appauldd's Avatar
Boost leak.
Old Oct 13, 2010 | 01:55 PM
nonschlont's Avatar
surge?
Old Oct 13, 2010 | 02:30 PM
SiliconTek's Avatar
Occupant weight is different and possibly temperature? I don't really see much wrong with it.
Old Oct 13, 2010 | 08:33 PM
veszett's Avatar
thanks for the idea's. i've ordered a boost leak pressure tester, should be here today or tomorrow thats what im suspecting. temps would have been pretty close on both pulls and also the weights are pretty accurate.
deej1
Sep 27, 2015 01:55 AM
desiromeo812
Sep 1, 2011 10:01 AM
l2r99gst
Midwest Region
11
Jun 14, 2010 02:20 PM
aka.ralliart15
10
Mar 15, 2010 08:45 PM
Hiboost
26
Dec 30, 2009 04:28 PM
