which injectors 4 my set up..
Old Jul 1, 2010 | 05:28 PM
grey~ghost's Avatar
Hey guys, i've been trying to research info on injectors sizes for my set up. mostly found info on e85 set up's tho. Here's mine..Fp Red ported, kelford cams, LICP, ported exhaust mani and TB, AEM tru boost controller, supertech springs and i'll be running 100% meh..can't determine if i need 850 or 1100cc injectors.
please help.
Old Jul 1, 2010 | 05:38 PM
awdturbo8's Avatar
1200 would be perfect. I used them on pump and 100 oct.
Old Jul 1, 2010 | 05:52 PM
grey~ghost's Avatar
a turner here was telling me not to go over 750cc or 850cc because the ECU can't handle anything higher without having start up issues. does that sound right? He also said that if i was running E85 then a 1110cc would be fine but since it's meth that 850cc should be fine. probably boosting 31-33 psi..
Old Jul 1, 2010 | 06:46 PM
Foolproof's Avatar
I was running pte 880's and with the first tune I was having start up issues but I got a retune and it fixed it. Didnt have a problem after that.
Old Jul 1, 2010 | 06:51 PM
ondatdro's Avatar
Pte 1200s ftw
Old Jul 2, 2010 | 09:23 AM
grey~ghost's Avatar
im just confused bc i see people running 1k and over but my tuner suggested nothing over 750cc for running full meth, fpred etc etc
Old Jul 15, 2010 | 11:34 AM
EVO8STI's Avatar
i hope you're ready for that meth to burn every sensor in the intake manifold!!
Old Oct 14, 2010 | 04:47 PM
grey~ghost's Avatar
ok guys im back, i finally have the funds for the rest of my build. but im still stuck on which injectors i need for my set up. not sure if im still wanting to run meth at this point. so my question is which injectors for with or without a meth set up. again my tuner says nothing over 770 or 880 for this build with meth, that anything over 1000 would be trouble. not sure what to do at this point...so confused.
(heres a list of my parts so far)
fp red 80mm ported tubro
ams LICP
ams intercooler
ported manifold
aem tru boost controller
kelford 272 cams
supertech dual valve and retainers
map 02 dump
meth? not sure...
Fuel Injector Clinic
Sep 17, 2014 09:25 AM
john ho
Feb 26, 2013 05:55 PM
bosco121
AEM EMS
Mar 31, 2011 02:37 PM
iTune
Mar 14, 2010 10:28 PM
evilevo22
Sep 9, 2009 01:35 PM
