iddle problem
Old Oct 6, 2010 | 07:36 PM
shangai's Avatar
iddle problem
hi, i just installed a new definition that holds alt fuel and timing maps. also the knock warning on the cluster. i passed the step tables as it was on my last tuned maps and the targets iddle. my last map with old definition worked perfect! but with th enew definition, i have iddle problems.. if i am on neutral and i accelerate the engine till 4000rpm, when it drops back it goes to low. some times the engine stops. i hate that cause if im stopping on a red light.. the engines stops itself.. any help?
my fuel maps till 80 loas are the same as the one on the old. also when i use the new def the temp was on c and the new one on f. so i change the c to f and put the same units on the steps.. please help me.. if i change back to my old defand tables. it works perfectly
Old Oct 9, 2010 | 08:14 AM
shangai's Avatar
no ideas?
