Hks f-con pro v - evo 5 - air temp sensor
Hey Guys,
Quick questions, random issue been having with my car starting after being warm!... it just turns over and turns over. I took it to a hks tuner over here in Japan and he said the ecu thinks the cars too hot therefore wont let it fire...
Anyway, I thought I killed this issue, i discovered that the AIR Intake Temp Sensor for the ECU is tapped into the Plenum Chamber... therefore if car is sitting after being running for a bit, that temp sensor would be red hot when returning to the car after 10-20mins thus reporting a false temp to the ECU....
Is it normal for this sensor to be tapped into the intake mani/plenum? I would of thought it would to be tapped into intake pipe, cold side of turbo???
Anyone shed some light as the issue is driving me nuts!
Thanks in advance!
Thanks in advance!
