Intake installation without tune
Old Feb 16, 2011 | 07:43 AM
euntaeyi's Avatar
Hey guys, recently installed the HKS Kansai airbox with the HKS bubble style air filter. My car had a tune on it prior to the installation but was running rich (10.8-11AFR) because I also had an exhaust manifold was installed. I don't have a tactrix to datalog so my concern is that I'm running dangerously lean. On partial throttle I'm seeing 12.5-12.8 AFR on my AEM gauge and I did a few 3rd/4th gear pulls at WOT to see that the AFR is flirting with the 12.0 range. My concerns are obvious here.. so if you guys could chime in with your 2 cents it'd be appreciated
Old Feb 17, 2011 | 10:17 AM
turbolarry's Avatar
Get the cable and logging software. You need to find out for yourself because anything else is a guess in the dark.
Old Feb 17, 2011 | 12:35 PM
euntaeyi's Avatar
Thanks for the input. Where's a good place to get the cable?
Old Feb 18, 2011 | 12:46 AM
turbolarry's Avatar
http://www.evoscan.com/evoscan-gps-o...flashing-cable
... or maybe track down a used one.
Old Feb 19, 2011 | 08:16 AM
MattC28's Avatar
Yeah, you dont have to buy the brand new 2.0, I have a 1.3u and so far it is fine. Reflashes and logs.
