Now that my Evo is fixed, is my tune bad?
Background:
Last year randomly during an autox event, my car stopped making boost. Went from 22psi to about 7 seemingly instantly.
I just recently discovered the problem to be a plugged Cat, I guess there was so much back pressure between the exhaust manifold and the cat that the turbo couldn't spool.
Today I took the cat out, removed all the catalyst and reinstalled it. Sure enough I am making boost again.
Now:
I have reason to believe the cat was in the process of dying the last time I had the car tuned, not completely plugged, but creating much more back pressure than a properly flowing exhaust would have. Now that I have completely removed the restriction is my engine at risk? I am concerned about potential overboost or some other conditions resulting from the drastic change in flow through my exhaust.
Car:
Almost completely stock... I have a Perrin intake to the compressor inlet, Grimmspeed EBCS, and now an empty OEM cat housing (the rest of the exhaust is stock also).
I appreciate any insight you may be able to give me.
Thanks!
-Bryan
Now:
Car:
Thanks!
-Bryan
Last edited by qucifer; Aug 9, 2011 at 08:49 PM. Reason: Fixed an errant click of the mouse.
