Wideband formula help. Innovate MTX-L ---> EvoScan
Im trying to determine if the new Innovate MTX-L wideband formula should be the same in the EvoScan software as the older LC-1 since EvoScan already has formulas for the LC-1. If anyone has had any experience using the MTX-L with EvoScan please let me know. Any help would be greatly appreciated! Thanks.
Im wiring the wideband output directly into the ECU wire (rear O2) and using that to log with instead of serial or USB. So im assuming this will work with any wideband this way, but im not sure if the formula is correct. (the range on the MTX-L is from 7.35--->22.4 for gas so thats why I used those values.)
7.35+(7.35-22.4)+x/255
Giuna99
Apr 17, 2016 07:35 PM
FS[MidWest]: Innovate digital AFR gauge
needsboost
Jul 12, 2015 03:37 PM
aggieEVO
May 1, 2015 01:17 PM
