ECU Swap
Old Apr 19, 2012 | 10:29 AM
duranvw's Avatar
ECU Swap
Hello,
So my current troubleshooting has led to to a possible problem with the ECU. I'm doing some final testing today.
I have an USDM EVO9, My question is if I'm going to swap my ECU with a used stock one is there anything to consider or revisions of roms that could cause a problem?
Thanks.
Old Apr 19, 2012 | 11:34 AM
dacowgod's Avatar
You will have to have the ECU programmed for your IMmobilizer if you're tossing a stock one back in...
You having an EVO 9 you can only swap in an EVO 9 ECU due to Mivec control..
Old Apr 20, 2012 | 05:47 AM
duranvw's Avatar
Ah yes right. I have ECUFlash and a Tactrix cable. When I had first reviewed my rom i noticied I never had a value in that field? Would I just clear it on the new ECU and be good?
Old Apr 20, 2012 | 11:47 AM
duranvw's Avatar
Alright so I do have a single hex value of 3201 on the Immobilzier screen. I should have no problem then if I flash this on to the new stock ECU?
Also does the Internal ID version number make a difference?
RobGinSki
Lancer Tranny/Drivetrain Tech
10
Aug 5, 2025 06:03 AM
nudge120
May 14, 2020 06:18 AM
LanEvo IV
Jun 5, 2015 04:46 AM
DRT EVO
Jan 19, 2012 09:39 AM
Tractionlimit
May 6, 2009 02:58 PM
