unknown error codes.
Old May 30, 2012 | 07:50 PM
chrisw's Avatar
So after fixing a dumb *** mistake on my part I had to clear codes from the ECU. I had been working on the injectors and had disconnected the knock sensor which disabled the fuel pump.
Once the dumb *** figured that out, I quickly had the car running and proceeded to clear the codes.
I got a p0334 - crank angle sensor circuit 'A'. This was expected.
But I also got two codes that I don't recognize.
U25A5
and
B0107
Earlier this year I removed the airbag module, and after doing some research I found that I have to bring the car back to the dealer to reset it after re-installing it. Also, the SRS light is still illuminated.
Could that be one of the codes? don't know...
Has anyone else seen these codes before?
Oh yeah, car is an '03 Evo.
