Injector Harness wiring
Old Jan 29, 2004 | 07:59 PM
JeffWels's Avatar
This is the correct wiring for the Injector harness
Injector 1 goes to ECU Pin 1 with the Blue and Red Wire
Injecto 2 goes to ECU Pin 14 with the Orange and Red Wire
Injector 3 goes to ECU Pin 2 with the Yellow and Red Wire
Injector 4 goes to ECU Pin 15 with the Purple and Red Wire
Thanks,
Jeff
Old Feb 11, 2004 | 01:54 PM
nonmature's Avatar
did you ever try this to see if it was correct???
I will be installin mine soon...
-non
Old Feb 11, 2004 | 10:35 PM
JeffWels's Avatar
yes what I have posted is correct. So this is now an injector harness wiring DYI
Old Feb 26, 2004 | 02:02 PM
nonmature's Avatar
jeff did you just tap into the wires???
-non
Old Feb 27, 2004 | 10:24 PM
JeffWels's Avatar
I just tapped them, i did not cut them, just stripped some insulation off the wire, wired in the harness and solder all connections
Old Sep 20, 2007 | 10:02 PM
dashiet's Avatar
old post but is red positive or negative?
Old Sep 28, 2007 | 08:06 PM
Spooldyou's Avatar
dont even waste of money on an emanage for the evo, Fries the coil packs, Use ecuflash its free
