Dead ECU
Dead ECU
So I am pretty sure my ECU just ate it...It started by not sending a ground to my Crank/Cam/MAF/MAP sensor circuit. Fixed that and it was running good again. Then I drove it parked it and now it turns over but will not fire. I Pulled out the laptop and it will not connect to the ecu through ecuflash or evoscan. So my question is will any Evo 8 ecu work or are there certain things I need to look out for? Also is there any other ways to check and make sure mine is dead? Thanks!
