Timing Mark
Old Oct 23, 2012 | 06:05 PM
bryonboals's Avatar
Timing Mark
Can someone snap me a pic of where the timing mark on the cam is suppose to be when the crank is at TDC
Old Oct 23, 2012 | 06:07 PM
bryonboals's Avatar
Mine is slightly on the inside of the mark on valve cover not right on mark is that right. only if I had a picture
Old Oct 23, 2012 | 09:44 PM
BLK_EvIL's Avatar
try and line up the cams as close as you can with the marks on valve cover then look at the crank mark it should be a couple degrees ATDC i belive most evos come from factory like this unless it was more then 5+ degrees off i wouldnt worry
Old Oct 26, 2012 | 09:32 AM
bryonboals's Avatar
I googled imaged it thanks all
denile
32
Aug 20, 2009 03:21 PM
dancarroll0283
Apr 6, 2009 05:28 AM
Evo_Tom2005
May 21, 2008 01:11 PM
honki24
Dec 20, 2006 09:43 AM
ez76
May 11, 2005 08:31 AM
