Stand alone maf reading converted to analog
Old Dec 12, 2012 | 10:28 AM
211Ratsbud's Avatar
Can somone suggest to me an air flow sensor that outputs an analog signal? Preferably one that was used on a FI vehicle.
Old Dec 12, 2012 | 10:56 AM
211Ratsbud's Avatar
Or maybe suggest to me an analog maf sensor ?
Old Dec 12, 2012 | 05:47 PM
211Ratsbud's Avatar
https://www.evolutionm.net/forums/ec...mentation.html
ahh.. i look for a maf off an X .. took a while to understand what I was looking for but my idea will work!
Old Dec 12, 2012 | 05:50 PM
211Ratsbud's Avatar
Originally Posted by 03whitegsr
I found a copy of the FSM and it had some interesting points about this sensor and how the ECU calculates airflow.
The sensor is a 0-5V output, not frequency unfortunately so whatever needs to be done for a Subaru sensor is the same that needs to be done for this sensor. Honestly though, the two sensors look very similar, they may even be the same sensor.
When used with the factory airbox
0.2 VDC = 0 g/s
1.8 VDC = 10 g/s
3.5 VDC = 119 g/s
4.9 VDC = 387 g/s
The MAF sensor has a built in thermistor which looks to have roughly the same scaling as the EVO VIII-IX IAT sensor in the stock MAF. This is just from memory though and I'd have to look at my notes to be sure. The X has two separate air temp sensors though and may deal with fuel enrichment very differently because of the two sensors.
The Baro sensor on the X is in the ECU. I also think it mimics the VIII-IX baro sensor on scaling but would have to look at my notes again. The X also has the 3-bar MAP sensor so there is likely additional mapping to accommodate MAP correction trims.
If an internal diameter measurement of the factory air inlet was taken near the airflow meter, we could probably calibrate it for other tube sizes pretty easily.
specifically this information. This is leading towards my SD car running a closed loop anti lag computer I am working on!
Evo11V
Jan 7, 2016 08:56 AM
h24
Sep 25, 2014 08:30 AM
211Ratsbud
10
May 2, 2013 06:21 PM
raytrix
Oct 26, 2009 11:10 PM
kaonashi
Nov 4, 2007 09:34 AM
