Logging turbo speed with the Garrett kit.
Old Apr 29, 2013 | 05:57 PM
211Ratsbud's Avatar
Does this kit have an analog out? Able to be logged by a spare adc in the stock ecu?
Old Apr 29, 2013 | 06:58 PM
240Z TwinTurbo's Avatar
no
Old Apr 29, 2013 | 07:04 PM
211Ratsbud's Avatar
Damn, I didn't understand the square wave business in the instructions
What kind of logging is needed to do this? Would it be a serial out put that evoscan can pick up?
Old Apr 30, 2013 | 10:27 AM
211Ratsbud's Avatar
Anymore input? Tsc?
Old Apr 30, 2013 | 01:38 PM
bsh's Avatar
bsh
You need a digital input that can count pulses. There is a gauge available from Garrett for turbo speed if that helps. Anyway maybe some electronic guys here can make device that make the digital input come out as a 0-5 V ie 0v = 0 rpm and 5v = 500.000 rpm and someone can make it work in Evoscan?
Btw I use it on my Vi-PEC ecu. Wired directly to a Digital Input. Works great
Old Apr 30, 2013 | 02:47 PM
211Ratsbud's Avatar
That's why I'm wondering if I can use a serial cable and log in evoscan. I need to test and verify my sas/als settings. Via shaft speed
Old Apr 30, 2013 | 02:48 PM
211Ratsbud's Avatar
Btw what vipec do you use ?
Old Apr 30, 2013 | 03:59 PM
03whitegsr's Avatar
I wonder if you could use the MAF input after converting to speed density. It is a square wave input that counts frequency after all.
Might have to hook into the IPW routine and pull the frequency out before it gets converted into an airflow reading which then gets over-written by the SD patch. I think the IPW section counts the total number of pulses per interrupt and converts it into a load. It grabs counter time also and at some point it gets converted to a frequency.
Old Apr 30, 2013 | 04:31 PM
211Ratsbud's Avatar
Already on sd,
Good ideas , not enough pull for a guru however.
So this isn't something that could be logged via independent serial cable? I'm not familiar enough with electronics to understand.
I could always look at the gauge but that has inherent risks.
Old May 2, 2013 | 05:40 PM
03whitegsr's Avatar
You could probably get somebody on the board to build you a simple frequency to voltage converter. You could probably even find one already built if you look hard enough. It would be a very simple circuit.
You could also build something based on the Arduino.
Old May 2, 2013 | 06:21 PM
211Ratsbud's Avatar
I have a Arduino UNO that I'm learning .
I planned to use it for my sas solenoids, but maybe it could do all of that and I could even shut the solenoids off based on shaft speed
stefenboy
May 20, 2016 07:51 PM
zebra4
17
Sep 18, 2013 09:19 PM
jameswwt
Apr 22, 2012 09:20 AM
allcdsrus
Mar 4, 2007 02:39 AM
4ringturncoat
Dec 10, 2005 06:46 AM
