ohms and recreating a circuit
Old Apr 30, 2013 | 08:02 PM
Wheatley's Avatar
I've replaced my oem fuel tank with a custom single side tank and now only have one fuel float. The oem wiring feeds through both in order to make the gauge work correctly. I really am only concerned with if its empty or not but if possible I would like the full sweep to work. From what I understand with this circuit that will not be possible.
I tested the saddle side float and came up with these values tested at the potentiometer.
5 ohm full
76.5 empty
The fuel pump side float.
5.1 full
39.5 empty.
Do you just add those together to get the full ohm sweep of the factory gauge?
10 full/116 empty
Since I'm removing one potentiometer from the circuit how do I trick the gauge into at least showing empty when its empty? Will adding a 76.5 ohm resistor fix the issue or just throw the entire reading of the gauge off?
These are the values another member posted on here from the service manual tested at the vehicle connector.
Primary:
Full - 6.5 (+/- 1) OHM
Empty - 41.2 (+/- 1) OHM
Secondary:
Empty - 78.8 (+/- 1) OHM
Old Jun 12, 2013 | 06:16 PM
EVO8_PR's Avatar
Have you been able to work this out? I'm looking into the fatfab fuel cell also, but being a "full street" car i'd like to know when fuel is low also.
Evolved-8
Oct 30, 2013 05:57 AM
ToddRhodes
11
Jun 12, 2013 12:12 PM
mrfred
Apr 21, 2013 01:17 PM
93civEJ1
Jan 30, 2008 11:32 PM
