Formula for AEM UEGO in Evoscan
Does anyone have a proper formula for the AEM UEGO wideband to function in evoscan? Evoscan seems to be reading about 4 to 5 points lower than the gauge does. I find this odd because I thought it used to be spot on previously, now it seems to be very off.
0.03913*x+10 is the original formula. However, sometimes you need to adjust it to read the same as you sensor. Some have put a 9 at the end instead of a 10. I sat there and watched my gauge on a log and 0.03913*x+9.7 is the formula that is spot on for me. Could be different on yours though. Trial and error is your friend. GL
Casey Robertson
Mar 22, 2016 04:32 PM
