anyone using UTEC yet? Post your results here
Is this thing identicle to the WRX one??? If so, then the instructions i downloaded are the same, or are there different instructions for the evo unit?? AND where can i get a book on tuning 101?? RRR
Originally posted by rraulston
for protection, will it pull timing when knocking???
If i get a wideband, will it integrate???
If so, then the instructions i downloaded are the same, or are there different instructions for the evo unit?? RRR
so if i buy your utec and wideband setup and hook em together, does the utec adjust my a/f ratio automatically based on what it sees? or do i still have to tune the a/f ratio?? Or do i just look at the meter and tune the utec???? Then what is the purpose of connecting them??? RRR
and one more question, sorry, but you seem to know what you are talking about, do i have to let the utec controll boost or can i keep the hks evc. Or can i set the utec to pull boost when knock detected??? how does that work?? thanks in advance. I know its more work, but when you drag my questions and answer them, its quite professional, it may have even sold you another utec. ime on the edge with cash in hand.... Ray
When the wideband is connected it will appear in the far right hand column, next to your relateable data. So when you go to make the change the afr ratio you know exactly what load site and rpm you need to make the adjustment. This takes the guess work out of tuning.
Regarding the boost control, you don't have to let the utec control it. You can use your EVC. It will not need to be in control of boost to function correctly. Our UTEC has it's own knock detection/correction system which has completely adjustable knock thresholds.
If you have a knock count it is capable of retarding the ignition timing at that load site up to 10 degrees and max of 30 degrees retard for 1 single knock count.
In the screen capture the utec is set:
For a (5) Knock Count it will retard timing (1) Degree up to (12) degrees of retard.
And after a 100 crank cylces it will set the timing back to what is set in the timing table at that given load site.
Using the stock boost to control the knock correction would be way too slow to blead off enough boost to be safe enough to rely on. And have consistent boost correction.
Jermaine~
www.turboxs.com
P.S. All question are welcomed and we are glad to answer them.
i think this sounds pretty good. Now i have an innovate LM-1 wideband. Ime hoping i can use it for now. Will it hook up till i can afford the other one you sell? it has 2 analog outputs, 0-5 volts with 10 bit resolution, and programable. I need to know if this will work. I dont think i wanna tune anything without using the datalogger.
thats what i needed to know. Will you offer an auxillary output for a wideband gauge, or will the digital one on the unit be it. Ime trying to figure out where i would mount that thing and access the serial port.... and thanks again. I wouldnt be asking a ton of questions if i wasnt interested....
Jermaine~
www.turboxs.com
whoa dud, thats awesome..... whup *** in mario kart and tune my car....lol
HEY is anyone here a rep from Turbo XS..... playing with the EVC and the AFC was easy.....the UTEC scares me, if I get it installed myself, would they tune it you think.?? I live SOOOOO close
-shahul
-shahul
-shahul
-shahul
We do offer dyno tuning as well you can shoot me an email at Jermaine@turboxs.com and we can talk a bit about that.
Jermaine~
www.turboxs.com
