Evo 7 ECU speed density rom
Old Oct 3, 2016 | 11:20 AM
wreckleford's Avatar
Originally Posted by german_evoVII
LHD EDM 7´s ( GSR ) didnt have an Map sensor stock, but it is possible to run SD with one wire connected to the Map input pin. (Pin position is free at the connector
Works flawless with the 9055xxxx sd Roms
The same but different Rom is applying to EDM LHD Evo 8´s GSR
I would be surprised if this 7 didn't work with the 9653 series of ROMs also. I have used 9653 on several 7s and other cars with 7 ECUs.
Old Oct 4, 2016 | 03:24 AM
german_evoVII's Avatar
Evo8 Rom might work also, but the 9055 is an better fit...
Some small things are different Hardware wise....
Old Oct 4, 2016 | 12:00 PM
What issues have you found?
Old Oct 4, 2016 | 12:20 PM
gvr4v's Avatar
We actually got it to start with a SD ROM (not sure which) in it, but it is missing(sounds like a Subaru) and the tuner is doing a great job, but if anyone could shed some light, would be great.
Old Oct 4, 2016 | 02:11 PM
10isace's Avatar
Both 96531706 and 90556701 work, but both have the timing jumping up and down several times a second. Never seen anything like it. It's got to be the tune because it didn't do that on 90550701 (MAF). Everything else looks great.
Anyone have insight?
Old Oct 4, 2016 | 02:40 PM
If that's an idle log it will do that as part of the idle control strategy.
Old Oct 5, 2016 | 12:10 AM
mines5's Avatar
Can you please check your cam sensor ?
Old Oct 5, 2016 | 03:25 AM
Main issue was that the EDM Evo 7 has an reversed Idle Stepper versus USDM / EDM Evo 8. Swapping some wires can fix that.
Edm Evo 7 Has the SAS System equipped. ( Also Purge and Evap simple system )
Immobilizers are totally different ( Evo7 MIS sys Evo8 + MEIS system )
Clutch switch also inverse for 9055 vs Evo 8 ( needed for the NLTS system )
nothing what makes trouble....normally
Major Difference : Throttle Body Evo7 has an High idle thermal actuator heated by the Water lines. ( similar to the DSM´s )
This was skipped Evo 8 and later...( maybe the 2003 Evo 8 still has that...)
This was one of the culprits when using an AEM 30-1313 in the Evo7, since the Idle was bouncing a lot during Warmup, since the Thermal Actuator worked as an Bypass for the Throttle blade by Water Temps and sometimes kicks in during Winter under Boost ( lift off, and the Rpm drops not fast enough to get back into Idle control )
Old Oct 10, 2016 | 04:04 PM
10isace's Avatar
Figured it out. There's no ignition signal from the ECU to coils 2 & 3. Getting that fixed and will report back. Thanks for all the suggestions!
Old Oct 10, 2016 | 10:51 PM
mines5's Avatar
Good to know this...
Just for the sake of knowledge , if there was completely no signal to coil 2 & 3 the car started up on 2 cylinders ?
Old Oct 11, 2016 | 05:34 AM
gvr4v's Avatar
It has 0.0v pulsing from pin #23 from ECU. Pin #10 has 0.2v pulsing from ECU.
Old Oct 13, 2016 | 05:08 AM
gvr4v's Avatar
Originally Posted by evo8vz
pay tephra
YEA, I have done that with no responses......
dom4g63
11
Dec 30, 2019 12:57 PM
1_blue_evo
Jul 6, 2017 07:23 AM
TheLancerLife
Mar 18, 2017 02:13 PM
raulbz777
14
Jan 27, 2017 05:02 AM
Tomvas1992
Jun 22, 2016 09:44 AM
