ECU Install
Old Jun 13, 2014 | 04:16 PM
Insanity Evo's Avatar
ECU Install
Hi everyone. So I am trying to figure out if my current ECU is broken. If I were to install a new (used) ECU is it just a full plug and play swap of ECU's or do I have to have it programmed or anything? My car is a 2003 Evo 8. Thanks!
Old Jun 14, 2014 | 10:31 AM
robbyredneck's Avatar
i wanna piggyback this thread. will swapping a new ecu in cause vin mismatch on an 8 or is the vin not embedded. sorry figured the responder could answer both.
Old Jun 14, 2014 | 02:59 PM
jrainwater's Avatar
As long as its a 2003 ecu w/o the immobilizer function I don't see why it would be anything but a plug n play affair. Second poster, I'm not sure I understand your question to be honest.
Old Jun 14, 2014 | 03:39 PM
Wondering the same thing. He is talking about when it is hooked up through the obdII scanner during inspection, will it still show as the cars original VIN or will the new ecu have the cars data/VIN still inside (will it not match the cars VIN it is registered under)?
Old Jun 14, 2014 | 03:43 PM
jrainwater's Avatar
Why does it matter if the vin matches? I'm jw. It doesn't really effect anything nor should it. Is there a smog or legal reason why this matters that I am not aware of?
Old Jun 14, 2014 | 09:12 PM
My ECU might be broken and I need to smog.
Old Jun 15, 2014 | 05:42 AM
in ny, the inspector hooks the car up through the obd port. if the car has a vin in the ecu and it doesnt match the vin on the dash your f-d. hence my question. i am looking at an 8 with an aem in it. so no obdii support. i would then buy an ecu and put a pass code inspection tune in it as long as there is no vin mismatch.
Old Jun 15, 2014 | 10:50 AM
jrainwater's Avatar
Well there is definitely going to be a mismatch unless you can find the ecu that was in your car originally lol. I'm sure there is a way to rewrite the vin in the ecu. I mean crap, we can change EVERYTHING else on the rom these days, why not the vin too? In Illinois they just plug you in and if all the test monitors show "pass" then you're done. People do ecu swaps all the time on these cars so I'm sure you will find the info you need using the search function of this website. Good luck.
Old Jun 15, 2014 | 10:58 AM
jrainwater's Avatar
The more I think about this the more I don't understand why a mismatched vin would cause you to fail emissions, people have ecu's that get fried out all the time and they just buy a used one and put their tune and immobilizer code on the new(used) ecu and call it a day. So you can't just tell the smog people that your ECU got fried and you had to buy a new one????
Old Jun 16, 2014 | 12:00 PM
i can tell the tech but nysdmv is less understanding . it's like the gestapo. no funny business in our state . thanks i will dig more
Old Jun 16, 2014 | 12:26 PM
jrainwater's Avatar
Lol @ **** police comment. Good luck brother.
Old Jun 16, 2014 | 02:02 PM
thanks j
Old Jun 20, 2014 | 06:33 PM
my goto shop says no way but the law reads it would flag the mismatch but pass emissions. looks like the may be a waiver also. any one?
greddy23
Oct 27, 2016 10:12 AM
Dnasario
Jan 16, 2016 08:52 AM
napsu67
Sep 19, 2015 03:08 PM
napsu67
Aug 23, 2015 12:32 AM
96_LXR
Jun 24, 2006 04:10 AM
