Boosting issue? Please help.
Old Jun 20, 2014 | 01:44 PM
Raziel's Avatar
Can anyone tell me if they have run into this issue?
I have pretty much a stock Evo 9 with zero tuning and after market BOV and aftermarket clutch.
I am currently only getting 10 psi from my gauge. It happened very suddenly and now I pretty much have no boost. I can hear the turbo spool, I can hear my BOV go off as normal, and I checked for possible leaks. I found no leaks but my Evo is behaving as if there were a leak.
I did a leak test on pretty much every possible thing I could find. I even also tried to open the wastegate and found the same results to see if it was a vacuum line issue/wastegate issue.
Could this be my turbo? Turbo doesn't make or react any different than prior to this issue. Could it be a wastegate issue? Could it be something else?
Old Jun 21, 2014 | 01:00 PM
Raziel's Avatar
*Update*
I fixed this issue by making sure all factory vacuum hoses are installed properly. I did not have the factory pill restrictor installed on the Turbo side. I had initially removed it due to the manual boost controller I had installed prior. I was restriction the turbo and vacuum system from operating correctly by removing the restrictor pill. I am boosting correctly at 20 now.
*Update*
Ferp
Apr 5, 2017 09:41 PM
Seth_Horton92
Feb 9, 2017 07:13 AM
galantman03
43
Feb 5, 2017 09:54 PM
4dooradam
Jun 21, 2016 06:29 AM
Lunaismaiwaifu
Jun 10, 2016 09:28 AM
