need help afr at idle is everywhere
when i am at idle my afr goes any where from 11-17 afr i have just replaced the iac because of this issue any idea? attached is my tune.
Is the 02 sensor working? Unplugged?
Some info regarding, injectors, fuel pump, regulators etc.... may help.
Evo scan data also is very helpful to measure fueling parameters during idle to see what is going on.
I cant remember the list of items off the top of my head but 02 correction is one of them.
injestors 2150s, dual 255 pumps fuel lab regulator 272 kelford cams. i can get a log of idle here pretty soon once i get home i can up upload them. now when u say unlpug 02 you are talking about front 02 or rear 02? and is it safe to do while the car is running?
I just looked through your bin file.........you need to smooth out the timing in the idle area. That could very well be the cause of ur oscillation. your injector latencies need some work too. anymods on the car?
ps. Unless you made the timing map the way it is to avoid uncovering the actual map, I wouldn't go wot on this map. that's just me!
I agree with detroit pistins. Need a tune (latencies are off, timing is off at idle). More importantly do not WOT on this!!! The timing is way too high at peak load. Up top is fine.
You need to log O2 Sensor Volts. What's your fuel pressure at idle?
