Evo IX without a stock ECU tuning question
HI guy
this is my first post. I got a evo IX GSR and having some problem with it now. hope you guy give me some idea.
The 9 is using the Hydra ems ecu 2.5 version now, the ecu is for evo 4-8, it cannot run the mivec becoz of old version. this is not what i buy, the last owner changed it.
and now the car is running 20g turbo but with stock injector. i m thinking change to 1000cc injector to give more power. however, i want some advice on buying a second hand stock ecu or some aftermarket ecu. coz if i get the stock ecu i hv to get back the Maf sensor and loom which i dun have, and it cost for fixing the code for immobilizer.
if you want to switch to the stock evo 9 ecu it is easy enough to disable the immobilizer. with the stock ecu you don't necessarily need to put back the maf. you could just simply go speed density. if you are worried with regards to tuning there are a lot of reputable etuners here that could help you.
RallySport9
Sep 9, 2013 11:12 AM
jameswwt
Apr 24, 2012 01:12 AM
Mellon Racing
Feb 1, 2009 08:03 PM
