Cant reduce fuel anymore in ecu, Significantly higher than map
Hey everyone, I am currently trying to tune my car and am having one hell of a time getting the AFR set up. My maps are currently in the low 8.00 range with the higher rpms maxing out rich at 7.4 via Ecuflash. I am almost guaranteeing that these values are off because of the MAF but I cant determine exactly what it is I need to change to get the map values even remotely close to the actual AFR's. I will attach a picture of both the maps settings as well as a log showing what the AFR's actually are. I have tried searching MAF scaling and MAF compensation but no look fixing this yet.
Anyone, logged another run this morning and my fuel is maxed rich from ECUflash and cant richen up the upper portion of my RPM range. Anyone know how to scale the map to be closer to the values in the ecu?
GetterDragun
10
Jan 14, 2011 05:40 PM
MidniteEco
63
Jan 7, 2011 04:15 AM
