Need help!!!!
Old Feb 25, 2015 | 01:08 AM
S13 @ FullBoost's Avatar
Need help!!!!
Okay guys this is embarrassing seeing how I do this for a living but I can not seem to figure it out for the life of me and I really need to resolve this issue !!
My 2005 Evo 8 ssl My check engine light doesn't work. My Ecu will show codes for example I have a test pipe. I plug my scanner in and it shows me a p0420. Normal but I have no light in the cluster. I have removed the cluster and replaced the bulb with a new factory bulb and I still have nothing. What do you suggest would be the next step? Now I have been tuned but this problem has been existent prior to the tune but I had my tuner set my ses light for knock. I really want to get this resolved. Please help!!
Also I have a egr code since I have been tuned and I check the vacuum line and sure enough it popped off so I put it back with a zip tie cleared the codes. Drove 2 drive cycles checked it again and it came back so I rechecked the vac line and its still on there ? that also has me stumped
Old Feb 25, 2015 | 06:22 AM
Ev0ikon's Avatar
Did you get any voltage across the leads for the bulb? I could trigger the light with something as simple as removing the gas tank lid while the car is running.
Old Feb 25, 2015 | 07:24 PM
No I did not text it at the gauge cluster. I am going to try and start at the ecu and see if its sending signal to the bulb. Lets just say its not what would be the fix?
Old Feb 26, 2015 | 07:09 AM
Ev0ikon's Avatar
You may need a new cluster.
Old Feb 26, 2015 | 09:00 AM
If the ECU is not sending the signal I might need a new gauge cluster?? Or you saying if I do check and I have signal it might be the gauge cluster. That would make more sense to me.
Old Feb 26, 2015 | 01:04 PM
Ev0ikon's Avatar
I think you understand what I meant. If you pull the bulb (knowing that it should have set the light) and you could not detect the voltage across the leads (for the bulb) then it's a bad cluster.
While the car is running it's very easy to set the light. On my Evo I just open the gas tank cap.
Earthen
23
Jul 22, 2010 06:43 AM
drc
Jul 19, 2005 08:33 PM
Kwman
21
Jul 14, 2005 07:34 AM
army685
Apr 26, 2005 05:43 AM
TeamNeXusOz
West Region
Jun 9, 2004 08:56 AM
