advice! evo 1 with 7ecu time for speed density
Old Mar 28, 2015 | 11:58 AM
mady4g63's Avatar
hi guys
had the old girl off the road now for two years finally had enough of finishing everyone elses so time for her now very close with engine build after sheering the crank in half two summers ago i was then running a 6.5tme ecu but have since fitted a 7 ecu to take advantage of the v7 sd maps that are around i have mapped my friends evo 1 with a 7 ecu on with maf so have a good base to run engine in after that will be doing the sd conversion i already have both gm iat and gm 3bar map but cant find info for the map signal on the 6 ecu it looks like people use the rear 02 input but i was hoping the is another input as wanted to have a permanent wideband installed and use the rear 02 for logging that so please guys help me help her evolve !!!!!!
Kidloco51
16
Feb 15, 2013 03:46 AM
E-Spec@Tach Motor Works
Jul 1, 2011 07:40 AM
diiirk@AwdMotorsports
Mar 8, 2010 01:01 PM
StreetThisEvo
Jul 8, 2009 08:31 PM
firehawkta2000
Mar 25, 2007 06:25 PM
