Utech \ Pruven Tunning. Wow!!!!!
Originally posted by Noize
How much boost is the car running on the pump gas map?!? Why will nobody answer this question?
If I knew, I'd tell you.
You might have better luck asking the owner through PMs, if you find out post back here.
The boost spikes to about 23lbs, but quickly drops down to 20lbs. The C16 map was about a half a pound more. The race gas map power was made with timing adjustments for the most part.
Ken@pruven
Ken@pruven
Originally posted by 93h22cvc
We did not add that much. We are not trying to push the limit with customers cars, however you might be able to get away with that much or more. We save all the experimenting for our own car and based on what we know from our 548 wheel horsepower EVO 8 we can get away with alot more, but you definitly need a bigger turbo to do so.
