GM IAT sensor wired to MAF harness
Old Apr 5, 2015 | 06:54 PM
2winscroll's Avatar
pulling out my hair on this one
94171715 phenom rom
instead of hooking into the fuel temp input, I hooked into the maf harness and set my IAT to MAT to 03.
So its just like installing the spoolin harness for MAT.
SD MAT scaling was all f^#! up until I changed "tempscalefuel" to "tempscale" then the correct values appeared in the table.
Loaded up the rom and took a look at mut 3a and mut 11..... 3a is reasonable @ 30 degrees, but mut 11 is pegged at 260 degrees.
I have looked everywhere in these forums and cant find any answers.
Old Jan 10, 2017 | 08:40 PM
redSLed's Avatar
94171715 phenom rom
I'm having the exact same issue as you. Same rom 94171715 sd v7 Phenem. If you changed from tempscalefuel to tempscale and exited ecuflash, does it automatically revert back to tempscalefuel next time you open the program?
I'm just trying to get proper table values in there with tempscalefuel selected using the 0E option for converting iat to mat and can't seem to. My 3a log is about 9 degrees off ambient and logging mat at 09 reference gets me pegged around 200 plus.
Did you ever sort this out?
Old Feb 16, 2017 | 01:39 PM
2winscroll's Avatar
I think I got it figured out but have since switched roms to 8653, SD Rom. I had more issues with EBC and consistent AFR's on this rom so I just switched over to 8653. Can't remember what I did, there are so many issues with 9417 rom POS in my opinion. Switch over too 8653 more options.
4g63evoeight
Feb 14, 2012 02:28 PM
Dynotech Tuning
Feb 13, 2012 09:19 PM
1QYK9
11
Sep 18, 2011 01:26 PM
recompile
34
Jun 4, 2008 05:43 AM
