UTEC Parameter file change
Old Mar 19, 2004 | 09:04 AM
nmyeti's Avatar
Guys, if you have already purchased a UTEC i noticed a small mistake in our default parameter file.
Take a look at the special constants parameters and change the TPS threshold for mapping % to 25.
This was set by mistake to 80% as the default value during UTEC development.
The benefit of the change is better part throttle mapping control.
-Nathan
www.turboxs.com
Old Mar 19, 2004 | 10:22 AM
MalibuJack's Avatar
Thanks for pointing that out.. I think mine is one that has that param set that way and was wondering why it was so high when open loop transition is about 30% on this car.
Old Mar 19, 2004 | 04:08 PM
nmyeti's Avatar
We set it during software testing here in the states, and for some reason it was never changed back to the default of 25%
I suggest everyone check and change this value.
-Nathan
www.turboxs.com
Old Mar 21, 2004 | 06:05 PM
rraulston's Avatar
you know, i did the change and now ime surging pretty good???? What does this change actually do???
Old Mar 21, 2004 | 06:40 PM
nmyeti's Avatar
This allows the Utec to take control a bit earlier.
What do you mean by "surging?"
Old Mar 22, 2004 | 08:37 AM
MalibuJack's Avatar
The surging is caused by the transition from the ECU in closed loop part throttle, to the UTEC's control, I noticed it this morning in the really cold weather, 25% is just before going from closed loop to open loop operation.. you can set it to 35% if you want to minimize it.. 30%TPS is when the stock ECU goes into open loop mode.. but I found at exactly 30% it still would surge when it transitions from being on-throttle (UTEC Control) to off throttle (Stock ECU)
Old Mar 22, 2004 | 12:20 PM
nmyeti's Avatar
If 35% works best, then I’d suggest using that on your car. The key here is to get it set very closely to the closed loop/open loop transition.
-Nathan
Old Mar 22, 2004 | 05:03 PM
MalibuJack's Avatar
Revision, in this weather on my car, 33 or 32% worked for me.. It doesnt go away altogether, but at 25% its SEVERE, cruise RPM's and the throttle position to maintain it is way too close to 25% that you'd be transitioning constantly while accellerating slowly or closing the throttle after passing.
Also, with an aftermarket exhaust, you might want to go through and adjust the boost map settings to 85-95 since the boost on my car is riding around 21psi consistently.. so I dropped it a little to get around 19.5psi and a little lower at lower load points to keep things a bit more sedate..
