Issue with EVO 5 injectors,no pulse from ecu on 2 Injectors
Old Dec 23, 2015 | 02:40 PM
Ben2904's Avatar
Hi All,
First post here and I'm looking for advice!
I've got a EVO 5 which recently threw a rod out the block, I replaced the engine with a low mileage 6 engine.
The issue I'm having is the car is not starting and I have put it down to injector 3 and 4 not getting a signal sent from the ecu to pulse.
What I've done so far;
Checked for spark to rule out crank sensor
Checked continuity from ECU to injector-Good
Checked voltage at injectors-12v
Checked Injector resistor pack, reading 6.8ohm across all 4
Checked fuel pressure-Good
Swapped injectors around- All 4 injectors working(Confirmed by cranking engine with fuel rail off on top of rags)
Checked grounds
Checked pulse directly from ECU using test light- A clear pulse 1 and 2, nothing from 3 and 4.
And finally I've changed the ECU and run all the tests again with same results
I'm currently seriously stuck and almost at the point of hiring a trailer and towing it 2 hours to a Evo specialist.
Old Dec 24, 2015 | 11:02 AM
CDrinkH2O's Avatar
1. Double check you have installed your cam position sensing cylinder correctly. It could be 180 degrees out.
2. Double check that pins 2 & 14 (drive for Injectors 3 and 4) are making good contact with the female receptacle in the ECU plug.
3. Back probe pins 2 & 14 during cranking for injector pulse.
3. It is possible both ECUs you used to test have blown injector 3 & 4 drive circuits. Get a known good Evo 5/6 ECU and retest.
Old Dec 24, 2015 | 01:14 PM
Ben2904's Avatar
How do you mean the cam sensor could be out 180 degrees?
I've tested yet another ecu, currently 3 different ecu's causing the same fault.
I took the cam sensor out completely and I'm now getting a spark on all 4 injectors so I'm guessing it's a cam sensor fault...
I'll keep this updated for future reference
Old Dec 24, 2015 | 09:18 PM
CDrinkH2O's Avatar
Item 5 is the cam position sensing cylinder. Used to tell the ECU when cylinder 1 is at TDC. It is possible to install it 180 degrees out of phase.
Item 1 is the cam angle sensor (CAS). These often fail because they are close to an unshielded exhaust manifold.
Old Dec 24, 2015 | 09:34 PM
CDrinkH2O's Avatar
The paint stripe on the cam position sensing cylinder should be FACING the CAS when the engine is at TDC, like so...
Old Dec 25, 2015 | 04:52 AM
Ben2904's Avatar
The engine was said to be running healthy before I bought it and I've not took it off, but it will be worth checking and always good to know, thank you! I'll update when I get the new camshaft sensor
jcsbanks
Jul 21, 2010 11:29 PM
MAD7BOY
May 26, 2009 06:25 AM
chad99evo
Dec 15, 2008 01:58 PM
Ev0six
Sep 7, 2008 11:08 AM
jid2
Sep 14, 2005 12:53 PM
