Please critique this tune
Old Jan 20, 2016 | 01:36 PM
rip's Avatar
rip
Guys / Gals - can you take a look at this definition for an engine with the following mods? [.bin file attached]
Pls advise if the definition is a safe tune given the mods – print screens (off ecuedit or similar software) for any issues discovered are welcomed, not asking for any trade secrets but what could be better or if any of the fail safes are appropriate.
Ambient temperature at location ~32°C to 36°Celcius
Thanks.
2.4 4G64 on 93oct with water/meth – CT9a chassis
Goal – 30 psi tune
Mods as follows:-
Heads
-Port and Polished EVO 7 head
-GSC R2 cams
-GSC 5041 springs and retainers
-OEM valves
Bottom End
-4G64 block
-Manley stroker pistons 86.5mm (9:1 Compression)
-Manley 156mm H-Beam rods
-ACL bearings
-AMS head gasket
Accessories
-Aftermarket FPR
-Stock throttle body
-Stock intake manifold
-FP exhaust manifold
-Turbolabs of america GT35r reverse scroll turbocharger
-Ported 10.5 backend
-MAP O2 eliminator downpipe
-3 in exhaust
-ebay I/c bar and plate
uicp short route
ID High Z 1000cc Injectors
3 port EBC
Stock ECU off a jdm E7
Water/Meth Kit
COP System
Again, your feedback is welcomed in an effort to learn more....thanks /rip
File Type: bin
Old Jan 27, 2016 | 06:45 AM
rip's Avatar
rip
logs attached - as per request
Old Jan 28, 2016 | 09:32 AM
lancerrally45's Avatar
1) Fix your throttle so you see 100%.
2) Boost leak test
2) Your load factor is incorrect.
3) Chances are your knock sensor isnt tuned correctly. 2.4's are noisey. Theres how to's, just search.
4) Log your boost
Fix those things and come back.
Im not bothering pulling up your ROM because I can already predict what your timing tables look like by what the log is showing...
tsitalon1
39
May 27, 2010 08:02 AM
mtags24
Lancer Aftermarket Forced Induction Tech
24
Oct 23, 2006 06:41 PM
Blue Evo 8
17
Oct 6, 2005 07:23 PM
