very odd problem.
Old Feb 14, 2016 | 02:54 PM
3gevoclipse's Avatar
very odd problem.
did a 10psi partal pull today. looking over the run and i notice one line my rpms go from 4700~ to 8k with 165 timing then the next entry is normal, back to 4700~ 6 degrees. i also had one entry where my load went from 175 to 0 wiht 31 counts of knock, next entry was back to normal. i have been having issues with my cable disconnecting ranomly in the middle of runs. could a poor connection at the obd port caus this?
Old Feb 14, 2016 | 06:38 PM
CDrinkH2O's Avatar
Yes it could. Suggest you fix any connectivity problems first.
Old Feb 14, 2016 | 09:01 PM
I took the obd port out of its mount, seems do be doing fine now
Old Feb 15, 2016 | 02:27 PM
CDrinkH2O's Avatar
Glad you solved it.
jake33
Jan 27, 2015 08:40 AM
evilution09
Sep 6, 2010 11:19 PM
Jon91TSi
Jul 19, 2007 05:17 PM
eccgangster
Apr 5, 2006 11:23 PM
