2006 Evo 9 stuttering?
Old Feb 23, 2016 | 06:49 PM
Kody Mills's Avatar
I bought a 2006 Evo 9 back in September of 2015. Ran fine for few months than started like misfiring at low gears, than over about month and half got worse to where it does it in all 5 gears. It only does it when I WOT. Most psi it will reach is between 13-16 before starts cutting out. From outside the car sounds like it's backfiring. If I am in 4th or 5th gear and gradually bring it up to 13 psi and than floor the pedal works fine. No stutter, no backfire. I actually reached 28 psi. Car tuned at 3200: 21psi, 4600: 25psi, tapers to redline: 20. Max was 25, so shouldn't something, like Watergate?, prevent from going above 25? I don't know a lot about these engines and how they work, been learning.
Couple weeks ago I took it to a local shop. He looked at the wires to the spark plugs and said I'm 90 percent sure it's the wires. We made a deal and said go for it. As soon as I left the shop I did a pull, it worked perfect all the way through 3rd gear(as far as I made it) other than it backfired once but no stutter. Thought it might of worked. Decided to do one more pull and I think the top of 2nd it it just misfired hard. It actually didn't wanna stay running. It misfired all the way back to the shop(sounding like a suby). They also changed 3 spark plugs because they were cracked. I changed those not a week before that. They also said that timing was at 45 and at top of boost was -4. Don't understand all the timing numbers but he said that, that's not right. I hope haven't forgotten anything but just to the point where I don't know what it could be. Vaccum seems fine, plugs and wires changed. Any ideas or thought would be great been almost 3 months like this.
O yeah other than that problem car runs fine out of boost. I'll Post links to the videos of what's going on. Thank you!
Old Feb 24, 2016 | 11:39 AM
evo8426's Avatar
Have you done a boost leak test?
Old Feb 24, 2016 | 12:54 PM
roni4g63's Avatar
evo 5th gear fluctuates boost when tuned, you should stay out of boost in 5th on stock ecu
Old Feb 24, 2016 | 05:51 PM
Kody Mills's Avatar
No I haven't. I assumed there was no leak cause I idle between -19 and -21 inhg. Unless it's possible to still have a leak?
Old Feb 24, 2016 | 07:04 PM
Enriquee's Avatar
You should really do a boost leak test. And also, have you checked the spark plugs and gapping on them?
Old Feb 25, 2016 | 09:14 AM
Kody Mills's Avatar
I haven't checked the plugs gapping no. Shouldn't they come pre gapped? Also what would you recommend gapping them too?
Plugs are brand new. Put in couple weeks ago
Old Feb 25, 2016 | 03:49 PM
Enriquee's Avatar
I personally gap mine to 0.024 but you should always check the gapping on them when installing new plugs as you never know if someone might have dropped them or something and messed up the gap
Old Feb 25, 2016 | 07:29 PM
Kody Mills's Avatar
Ok thanks!
Old Feb 29, 2016 | 07:31 PM
Kody Mills's Avatar
Amazing!
I took the plugs out and checked their gaps. They ranged from .032- .038. I put them all at .024 and runs perfect. Thank you!!!
Old Feb 29, 2016 | 10:58 PM
Enriquee's Avatar
Originally Posted by Kody Mills
Amazing!
No problem man!
Old May 13, 2017 | 12:52 AM
Tommyfacekicker's Avatar
Damn. I wish I could fix my car that easily
wyattv
Dec 17, 2014 06:21 AM
rpople
Sep 19, 2013 09:22 PM
Laz
Mar 12, 2012 04:24 PM
ThePresley
Dec 4, 2011 12:07 PM
SethWillits
Apr 14, 2009 09:59 AM
